Ticking noise
82ndJumper
SoCal
2016 1500 SLT
2016 Ram 1500 Hemi 59000 miles, I got a ticking at start up for about 20-30 seconds on the passenger side of the motor, I think it’s in the front, then it goes away. I’m thinking warped exhaust manifold or maybe a lifter. Any ideas? One last thing is it just started about 4 days ago.
Burla
2010 Hemi Reg Cab 4x4
Welcome to forum, it's either your exhaust bolts or lifters, known issue and it's about 50/50. It is something the dealer should fix because of how easy is it to drill into something you don't want to drill into. If it's lifters, read my redline thread in my sig.
It's called hemi tick, research it.
Trody17
Middle tn
I have a 2013 Dodge Ram and I have had the same sound two times and both time it was the exhaust bolts. The dealership told me if it was lifters the truck would run really rough and you would know.
ChevySlayer69
Maine
Sounds like manifold bolts... And you are luckily still under warranty.
82ndJumper
SoCal
2016 1500 SLT
Update, manifold bolts was the issue. Still under warranty so all is good. Thanks for the reply’s.
Trody17
Middle tn
No problem. That good to hear.
CVX20
Ont,Ca.
2019 Classic Express
The valve train(lifters) can and do make noise without running rough.An exhaust tick would take a lot longer to go away if at all.If it fires and ticks for a few seconds that's lifters IMHO.
Caltfillisch
Wisconsin
I have the same issue but only when shifting into gear I hear the ticking. ???
