Tight steering
Tmann
Hunt County Tx
I’ve got a 2018 Ram 1500 4x4 with 50,000
Miles on it. The truck has a 6” Rough Country lift. Recently the steering doesn’t want correct itself. I installed a new intermediate steering shaft but didn’t fix the problem. Any ideas would be appreciated. Thanks
Dean2
Near Edmonton
Tight before lift kit or only after. Rough country are not well made kits and anyone that did the install should know better than to use one. 6" lift takes a lot of extra parts to keep all the angles and geometry right and RC kits typically don't get that right.
T
Tmann
Hunt County Tx
I’ve only had it a month and the lift was already on it. But it has gotten worse since I’ve had it.
CanuckRam1313
Ontario Canada
2023 Warlock
If it's a 6" lift you're wanting, then remove the RC components and do it with better all encompassing components ;)
T
Tmann
Hunt County Tx
To be honest I’m really considering dropping it to a 4” lift. Just hope that it fixes the problem.
Dean2
Near Edmonton
You can run a 6 inch lift if u want but any lift/level over 2 inches needs to be really well designed. Either take it back to stock or spend the extra cost for a top notch lft system. There are a ton of threads on here laying out good ones and all the stuff that is needed. There are also some great vendors on here that are experts on the subject and well worth contacting.
joshhhh
