Timbren input requested
Fearfact
I was hoping for some product input.... I run your front/rear in a bunch of our work trucks with great results! Now I need to do front on my 18 ram 2500 limited w/the Diesel engine. I’m running a plow which weighs about 900lbs. On two previous trucks I used part #dr2500d which helps great with the added weight but killed the ride when w/o the extra weight... the recommended timbren parts # for this truck is df25004b which has a higher weight rating than the ones I’ve used prior...this truck needs to maintain a better ride quality (change is expected) but hold the plow weight w/o collapsing the suspension as it currently does... anyone running this setup?
I will eventually add a 2” thuren suspension package as that made a great setup on the last truck when combined with the timbrens...
Chirnak
