This does not work.I find the TPMS sensors to be nothing more than an expensive annoyance. Have the ones taken out of your stock wheels and put in your spare, that way the only time you'll be bothered is if the spare gets low... which might actually save the day sometime!
This does not work.
The signal is received at the tire location, when they are spinning. This is why when you rotate your tires, the tpms monitor knows the new location of the tires.Details? How do the sensors know which tire they are in?
Correct. Plus they won’t be spinning, either. Your theory would be the same result as if you removed the sensors from the tires and threw them away.So you put them all 4 in the spare and that's supposedly too far away from the wheel hub for them to transmit?
I have also found that some replacements dont match the OE ones . Before I bought new tires they matched my digital tire gauge perfectly. Mavis put new sensors in with the new tires now they read a pound less. It dont sound like much but I run these damn 10 ply tires a little on the low side . Now I end up with the warning light on more often than it used to .
