Tire pressure system acting up
dpinvidic
This guy gets shotgun
Cave Creek, AZ
2014 RAM 1500 Limited
New 2014 RAM 1500 with 350 miles.
Was driving on the interstate at about 75 mph and the tire pressure system displayed a message. I noticed one wheel had dashes instead of the PSI reading. by the time I stopped, all four wheels had the dashes. Checked the tires and they were all fine. Stopped and started the engine, and it seemed to reset.
Anyone seen this? I hope it is not the beginning of a bad thing:Pshyco:
Dan
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
my warning would chime at startup because my rear tires were like 5psi low, now they're about 8psi low and the warning has been off for a few weeks....seemed to stop when we had 1 really warm day. As long as you've physically verified the psi with a gauge, it's safe to ignore temporarily. Never seen it with dashes, hopefully someone will have some ideas.
12TrueSport
San Diego, CA
2015 True Blue Pearl Sport
HEMI 5.7
The TPMS on my 12' does this every now and then. One sensor will go out, usually the left rear. It's usually when I use my HID fog lights. All I do is pull the fuse for a few minutes and reinstall. Next time I drive the system re-calibrates and the system is fine for quite a while
dpinvidic
dpinvidic
Cave Creek, AZ
This problem is different than low pressure. The system actually lost the readings from all four tires. Normally the EVIC shows the actual tire pressure for each tire. so if it was low, it would still display the value.
The numbers disappeared, and I just saw "--" for each tire.
Re-starting the engine seemed to reset the system, and it was fine the remainder of the trip.
Dan
sausec17
Banned
ATLANTA
time for a visit to the dealer...unfortunately I dont see anything you can do about that to fix it yourself. Seems like a programming/computer problem
RMMCBETH
Colorado
I have this issue with my 2013. The issue is in the gauge cluster/computer communicating with the dash. The fix is a new gauge bezel with the new software and reprograming the computer to read "Heavy/Normal Load Tire Low Pressure Threshold - Rear/Front" @ "32" PSI through a dealers wiTECH system.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
Had a similar problem but only the two rear sensor read "--" , happened within 100 miles of brand new. Dealership replaced both in tire sensors, 1000 miles later no problem. Hope you get it fixed up. Let us know.
dpinvidic
dpinvidic
Cave Creek, AZ
I am now at 2800 miles and it has not happened again.
Not going to let the dealer mess with anything.
Dan
Sent from my SCH-I545 using Tapatalk
LB3711
Trumbull, CT
3.6L V6
my 2011 has done it too. I just deal with it. I check my tires so I know I'm good.
mikey0302
My 2013 does the same thing, right rear goes red. 3 new sensors and a new module, and it still does it. No mods to vehicle, to cause this. The HID I might understand as the Rams use a powernet system that checks voltage on the systems. HIDs can mess with the system if they do not have he correct capacitance in the system to over ride the issue. This was the cause of the light flash issue years ago when they switched to this system. Good luck and let us know what you find as they have not corrected mine as of yet.
camsram
NS
My 2014 has done this a couple of times, most recently it lost FR, then BR then all tires were reading -- after about a minute. Pulled over on the deserted country road to restart the truck and see if that fixed it. Personally I found the following 5 minutes of 'No Key Fob Detected' and the truck refusing to restart (no matter what I tried) much more concerning than the tpms issue... :/
Sent from my SGH-I747M using Tapatalk
