tire question
lmeavtitn
Omaha NE
2015 Ram Rebel
I am going to be ordering new tires for my truck here within the next few days. I have a 2003 Ram quad cab short box 4x4. Right now I am running 265/70r17.but would like to go to a mud tire and larger. I am curious as to what the tallest and widest tire I can fit under it. I do plan on a 1.5 inch block lift in the rear and a 2" lift in the front before I throw on the new tires.
Any help would be appreciated. Also, i don't want to completely fill the fender-wells with rubber - I still would want some space for the tire to travel.
lmeavtitn
lmeavtitn
Omaha NE
2015 Ram Rebel
I'm thinking about going with the BFG T/A KO 315/70r17. Will that fit with no rubbing issues on a leveled out 1500 4x4?
Deviate
St. Augustine, FL
2005 4x2
Height wise I think you would be fine. Width wise I'm not sure. But someone should be along that knows for sure before too long.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
they will rub if you have stock wheels. i have 4.53 backspacing on my wheels with 35/12.50/17 and they rub a little bit at full lock when you hit a small bump. i am leveled out in the front.(about 2" in front)
