Tire recommendation with Fox 2.0 Coilover
Cameron Steadham
Euless
I am installing Fox 2.0 2" lift coilovers on the front with Fox shocks and a 1/2" spacer on the rear of a 2017 Ram 1500 4wd. Keeping factory 20's and thinking of 285/65/20 or 295/65/20 BFG KO2's. Anyone have any images of similar setups or recommendations?
Thanks.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Thanks.
Are you looking for the stuffed look?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
A 33” tire is a clean look on a 2” level yes you can pull off a 35” but it will be stuffed. I would recommend a 285/60r20 for that set up if you’re looking to stay on the larger size tire. If you want a clean nice riding stance I would drop to a 285/55
C
Cameron Steadham
Euless
Thanks, really just looking for a clean functional set up with tires taller and more aggressive than stock. Stock is a 33 so figured the 285/65/20 being 34.5 would be a good fit. I will look at some with the sizes you suggested. I appreciate your input.
