Tire size fit?
scmowry
Will 37x13.5 with 20x10 with an -18 or -24 offset work? Lift would be 6' with bilstein at 2.1 with rear spacer.
S
scmowry
I am new to all this and being deployed makes it so hard to get the info. Do you know much about the lifts, gears ect?
S
scmowry
Im debating between the Nitto and Toyo. What I should get with what. The rim regardless will be a 20x10 now just need to know backspacing with each tire.
atticusfaul
Boise
Nitto and toyo are the same manufacturer like Goodyear and kelly...I think :)
Sent from my iPad using Tapatalk HD
S
scmowry
Well Toyo is the tire I want and they come in a 13.5 so could I fit a 20x10 wheel? if so what backspacing? -18 or -24?
S
scmowry
Great! No no rubbing or trimming needed with the lift I want to get?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
No rubbing. I would go with the 4.5 backspace and a -24 offset. With the 12.50 wide tires you will have no rubbing what so ever. The tires also stick out from the fender wells a little....and looks great IMO!
S
scmowry
damn if I do 12.5 I have to get Nitto. I really want the Toyo but those are only 13.5
BAILEY1
2017 RAM 2500
Dat Cummins!
Those wheels are F'n sweet!! I don't think you will have any issue with rubbing if you go with that set-up. I can only swear to the 12.50 not rubbing because I have seen that set-up on several rigs......no rubbing. Go for it! I think you'll be good to go!
Musclemckeester
Houston, TX
n/a
n/a
My setup is Mud Grappelers 37x13.5 on 20x10, 4.5" bs and -24mm offset and I have no rubbing. If you want to go with a 13.5" wide tire then you want the 4.5" bs or if you go with a 12.5" wide tire you'll be fine with 5" bs.
