Tires for 3500 Dually
SkyHog
South Dakota
Can I run 315/70R17 tires on stock rims with no lift? will the dual wheels rub? Anyone have any experience? I have a manual transmission and would like to raise the gear ratio a little 34 inch tires would do it. I have watched youtube vids most folks don't get improved tire life until they get to a lift and 22.5 tires.
Thanks for any help anyone could offer in advance
SkyHog
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Stock rims are 6" wide. Anything bigger than 235 is not rated for a 6" wide rim. Lot of people fave run 255/80-17 without issue.
Sent from my SM-T350 using Tapatalk
2003F350
6.7 CTD
If you plan on carrying any kind of load, you don't want to reduce the clearance between the rear tires by much. As said above, 255's are about the widest I'd go.
My dad has been driving duallies since 1986, so he's played around with this a lot. You just really can't go wider unless you put in spacers between the rear wheels, and if you go too far you need longer studs.
I honestly get a kick out of guys who just throw wider tires on them - it's their time bomb.
Quyonmob
Canada
255/80/17s have pulled many a dually duty without issue. I’ve seen 265s rub each other under load.
rampower2012
Sioux falls sd
You can also check out is what it's called a super single as to them having dual tires in the rear you will have a single tire is called a super single you might want to look into that as well if you're looking to do so that might give you some ideas
2003F350
6.7 CTD
According to my brother-in-law, who works at a truck service station, the super-singles are only available in 22.5" tires. They are not available for 19.5" tires or smaller as yet. You can get wider tires in those size ranges, but they are not rated for the loads a dually can handle.
