Tires
Tracerex
Charleston, SC
Cummins 6.7
2013 2500 Big Horn Mega Cab SRW
Probably about 6 months away from a new set of tires. The stock 17" wheels seem way too small. I'd like to put 20" rims on it but I don't want to do a lift. What is the biggest tire I can use if I go up to a 20" rim and also what if I stay with a 17" rim?
Thanks
Bird
Phoenix AZ
33's on 20's and 35's on 17 would be my guess.
loveracing1988
Clarkston, MI
Depending on offset and width you can go to a 33 or some 34's, but that is it without a lift or offset control arms. The 2014 and later 2500's can fit 35's stock but the previous trucks hit the control arms.
ZCR1
I’ll be getting a set of BFG All-Terrain T/A KO2 LT275/60R20 w/D load range when I get back to the states in a couple months. They are 33”, same as the stock Good Years. I don't think there are any E load range 33" x 20's, which might be more desirable for a 2500.
loveracing1988
Clarkston, MI
The tires that come on the 2500's and 3500's are load range E with 20" rims.
ZCR1
Ahh, ok. I only looked at the 2013's at Tire Rack which showed 265 70 17 as the largest stock size rim/tire those are 32's. I guess they added 18 & 20" wheels with the refreshed '14's.
6.7CumminsDrvr
The Dude abides………
Georgia
Stock 20's are 285/60/20's so I'd bet a 286/65/20 or 295/65/20 would clear.
kealiher2004
I have a 2015 2500 6.4 Laramie and I am running 35x12.50x20's on worx beast mode wheels with a + 18 back spacing and mine don't rub at all.
Sent from my XT1096 using Tapatalk
jadocs
I'm not sure how wide the stock rims are, but you have to be careful running wider tires that are meant for wider rims. It causes an effect called "ballooning". It will cause uneven wear patterns. The wider the tire the more pronounced the effect will be. Like I said I don't know how wide the stock rims are so I can't say if it would potentially be an issue.
kealiher2004
I believe stock rims are a 9"
init6
Marion, OH
`14 2500 CC bighorn. Level up front running 35x12.5 goodyear mtr on 20" moto metals. Rubs plastic on full lock. Some trimming required. :)
