Tow hooks for Warlock?
Win94
Utah
Has anyone found tow hooks that will fit a Warlock? The Warlock opening in the bumper seems too small for all of the tow hooks I've found that would otherwise fit another trim.
crazykid1994
Pictures? The 4th gen tow hooks are all the same size wether from the rebel or non rebel. 2009-2018 and ram classic.
A_mod_too_far
Colorado
No they aren’t
warlock needs 68248844aa
and bolts 6104454aa
they are closed loop where as the classic uses hooks
I put them on my sport just to mix things up
crazykid1994
No they aren’t
and bolts 6104454aa
Funny. The warlock is a 4th gen. Some came with open hooks. Some came with closed loops. All are still 4th gen frames and all can take either hook. And they are the same size. One is just open.
A_mod_too_far
Colorado
They bolt up the same but the loop style protrude further and are narrower, but yes interchangeable, ram may only use the hooks now to reduce sku's and because they are less than half the price of the loops for whatever reason since the warlock is the budget version of the 4th gen rebel
KingEnder13
Portland, OR
No they aren’t
and bolts 6104454aa
Do those closed hooks fit both sides? I couldn't find the part number for the other side but I'd imagine they'd be different. Also trying to find the correct bezel for the warlock bumper. Ram didn't make it easy for warlock owners to find correct fitting parts since they mashed up multiple trucks on this Classic trim
A_mod_too_far
Colorado
They are the same both sides
Probably better off looking up parts for the 2018 rebel. I have the bezel part number as well, just not at my computer right now, but theres a thread on this site for converting a 4th gen front end to the rebel and it lists all part numbers for stuff like that
Also you will need an 18mm deep well socket for this job. Wierd size I didnt have
KingEnder13
Portland, OR
Thanks. If you have a link to the thread that would be awesome. Good heads up about the socket too
A_mod_too_far
Colorado
In this thread, benny from allpartsmopar posted a pdf that has the warlock bumper parts list
W
Win94
Utah
No they aren’t
and bolts 6104454aa
Thanks, this is exactly what I need. As you mentioned in another post, for tow hooks to fit the Warlock they need to be narrower than the one designed for the straight Classic since the bumper opening is narrower.
chriscon08
v6
does anyone have a link for front recovery hoooks that will fit a 2021 warlock classic
Lurchav8r
