Tow mirror upgrade
gsxr_kid
WV
Has anybody changed the stock mirrors on a Express to the lighted flip up tow mirrors?I installed some on my 12 Express yesterday and the lights dont work. The new ones had a extra plug that I pluged in under the wire for the power side of the mirror. The power contol works but the lights dont. Is it a fuse that needs installed or does it need reflashed or will they work at all?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
reflash is probably needed.
LB3711
Trumbull, CT
3.6L V6
theres a module in the door the mirror plugs plug into but like Jeremy said I bet the truck needs to be reprogramed for puddle lamps.
Look right above the speaker in this picture thats the module. Click to make bigger
G
gsxr_kid
WV
Yes I do have them plugged in but they still dont work.I guess I will have to call the ealer on monday
LB3711
Trumbull, CT
3.6L V6
gotta love these newer vehicles. gootta get them reprogrammed for the littlest things
garner
Harker Heights, TX
I believe that even with the reflash it won't work if it wasn't incorporated in your evic to begin with...or if you don't even have a evic. That's what somebody on another forum said one time when he swapped from non turn signal mirrors on his 2010 trx to turn signal mirrors
sullivan
Houston, Texas
Why not wire those suckers up yourself and skip the programming and head aches all together?
quietpeen
2021 TRX
Hellcat
I agree with reflash
sullivan
Houston, Texas
Have to program in order for the lights and turn signals(I think) to possibly work
Well I know with a bit of wiring you can make anything happen, it would be custom of course. Isn't a reflash like $200?
LB3711
Trumbull, CT
3.6L V6
I dont see why you couldn't do a custom wire bit. Just to need the know the pinout of the plug and where to hook it up to. Anything is possible
riggz
*******, GA
The flash is only a labor cost. I had mine flashed for under $75 once and $90 another time (different dealers). If you plan on adding other things, I would wait and have them do it all at once so you can get a better deal.
G
gsxr_kid
WV
My dealer told me today that the lights will not work on my truck. Has anybody done this on an express ?
garner
Harker Heights, TX
There's something about it not being in the computer even after reflash. Guy on another forum had a 2010 Trx and had the same issue. Plus you have to have an evic(he did) not sure if you do though
G
gsxr_kid
WV
No I dont have a evic my truck is an express
garner
Harker Heights, TX
Well wasn't sure cause with a trailer brake controller you get evic on the express so that's why I asked. But even with one, if your truck doesn't have those mirrors from the factory it won't work
sullivan
Houston, Texas
If you really want to get down and dirty, I can help you find the wires you need to tap these mirrors into. It would be an easy job.
G
gsxr_kid
WV
Wish I would have know about the evic with trailer brake I would hve ordered my truck that way. Thats what it looks like I am going to do is my own wireing.
