Towed 6000# Yesterday - Observations
GRN69CHV
Pennsylvania
I had to pick up a load of flooring yesterday (100 mile round trip). Original plan was to split the load between my 2900# gross utility trailer and truck bed. Plans changed, load grew to about 4000#, so we borrowed a tandem axle trailer, which was a better plan anyway cause the tandem has brakes, my utility trailer does not. Trailer weighed a hefty 2000# empty, along with the 4000# cargo there was 6000# tow weight.
Previous discussions, I had listed the truck had 3/4" rear spacer added, then a set of AirLift 1000 bags, with final setup being 3/4" spacer removed and just the Air Bags remaining, being ran at 20-22PSI along with a set of Monroe Reflex rear shocks (which has resulted in much in much improved ride and handling).
Ended up pumping the air bags up to 25 PSI prior to picking up the trailer. I should've taken a picture, but the squat was minimal, just about leveled out. Front end is lifted 1.5", with the air bags installed and pumped to 20-22PSI, it still maintains about 1.25" rake unloaded.
Towing observations, truck has 3.21 gears. In tow/haul at 60 mph it did not want to shift above 6th gear ( direct 1.00 ratio) which is fine, 7th and 8th gear are deep overdrives and from my experience over the years, nothing kills a trans faster than heat build up from low engine RPM and increased stress running in overdrive. Even in 6th, it was running just under 2000 rpm, still pretty low. For comparison, I tried dropping it down to 5th for about 10 minutes ( which would be closer to running 3.92 gears in 6th) just to see what effect if any on temps, there was no noticeable change. For you guys running larger than 33" tires, maybe you need the deeper gears, my opinion, running 33" tall tires, 3.21's are plenty.
Coolant stayed at 200-206
Oil Temp was 220-225
Oil Pressure was 51 PSI (36 at idle IIRC), truck has 61,000 miles on it, approx 2400 hours.
Trans temp was 185
Fuel mileage was mid 14's.
I live in eastern PA, some rolling hills, nothing severe. Overall, I was impressed at the performance.
My truck weighs 5600# , with that 6000# load behind it, that was a combined weight of 11,600#.
mtofell
I always like towing dense loads like that compared to a my 5th wheel/sail. I've done a couple hauls towing cars on trailers and it feels like it's on rails compared to the RV. Your temps look to be right in line with what I see when towing.
GRN69CHV
GRN69CHV
Pennsylvania
I just wanted to provide some detailed feedback. I won't do this kind of towing often, just wanted to share.
FYI, air temps were low 90's, so fairly hot to boot. I was more than satisfied.
Murdock188
Fulton, ny
2025 bighorn lvl 1
3.0 SO Hurricane
Those numbers are right in line with temps I see while towing my 24 ft TT 4900# dry prob about 6k after water propane batteries ECT, I only get 10 mpg though lol
GRN69CHV
GRN69CHV
Pennsylvania
You've got a lot more drag with that TT and probably pulling more hills.
Also, what gears does your truck have , what speeds do you travel at. I towed a TT years (decades) ago with a Chevy 2500, fuel consumption went up real fast as MPH increased.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Good write up, thanks. Looks like it handled the load well.
Murdock188
Fulton, ny
2025 bighorn lvl 1
3.0 SO Hurricane
Ooh definitely have more drag my truck has the 3.2 gears I don't travel at high speeds 65 max on the highway 55-60 normally and last trip was to the Adirondacks so lots of up/down hills and such so that's probably why I got 10 mpg lol if flat roads and 60 mph I can get like 13 or better but that's under ideal circumstances
electricalservice
