Towing with 2500
TWILLIAMS9
So my rig is a 2014 2500 6.4L. With a trailer that is around 7,000 lbs, will I need a WDH or some type of sway control? Trailer is 30ft. I know I'm rated to tow 15,000 pounds, just wondered about control.
smurfs_of_war
Swift Current, Saskatchewan
30'? Yeah, even with a 2500 sway can be an issue if you're not careful. You'll already require a weight distro hitch based on the tongue weight (that's a law in most places no matter the size of the tow vehicle) so might as well get a good one with the integrated sway control. Better to have it and not need it...
MADDOG
Living in a Firepit
6.4L HEMI
Yes, you will need anti-sway and WD.
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
I have a WD hitch and a sway bar but my sway bar is crap (the type with the break). As expensive as it is I think I'm going to go get a Hensley. They guarantee sway elimination based on their design. Anyone else used a Hensley before?
mtofell
Same truck and very similar trailer here. Yes to the sway control 100% of the time. WDH? I have it and use it most of the time but I honestly don't notice much difference w/o it. The tongue of my trailer is +/- 1000# while the payload of my truck is around 3000#.
BoldAdventure
Airstream, USA
Check out the Propride, Hensley designed it and left his original company to restart this one. Improves on the design and weights a bit less.
Spent the weekend chatting with several who had both the Hensley and Propride, we're pretty much sold. We've been using a Reese dualcam as that came with the Airstream, but when we get to New York, I'll probably be switching to the Propride. Setup is one time and hook up is mind-boggling fast.
To the OP, a good WD/Anti-sway is worth it's weight in gold. Don't be one of the guys who thinks they can just tow on the ball however they want because they have a big truck. Over confidence kills.
regularcab2500
Buffalo
5.9 Magnum
Lets not forget this truck is absolutely massive. What kind of drop mount do you have..12" lol?
BoldAdventure
Airstream, USA
I don't think 6 inches will be enough, here is a 6 inch drop Reese on my truck
Went to this from a 4 inch. With a weight distribution setup you aren't on the bottom.
TWILLIAMS9
TWILLIAMS9
Well it appears the 30 footer is going to be too long for where we want to camp. So we are limiting ourselves to a 26. Looked at a jayco 26BH without slides and the dry hitch weight was only 420. I honestly do not see the need to have a WDH for this. Am I wrong in thinking that? And yeah I'll need about a 10" drop. What are our stock trucks running for a drop?
smurfs_of_war
Re: needing a weight distribution hitch. The dry tongue weight will likely increase significantly from the brochure. My 26' Jayfeather has a dry tongue weight of 530lbs, but when loaded for the road without water it can push 650- 750 lbs.
Your manual can tell you whether to use one, also check regulations in your area as well as areas you'll be towing through. Some areas require it if your trailer grosses more than a certain amount. It has to do with the attitude of your steer axle in hard braking and maneuvering situations.
You won't need anything insane for a 26', but don't get junk either. I love my Blue Ox, and others have their own preferred brand.
With a 2500 you have way more than enough truck, but certain items apply to all light duty trucks across the board, regardless of chassis.
regularcab2500
Buffalo
5.9 Magnum
I run a 6" drop on a 2" ball mount because nothing that requires a 2" ball is gonna have enough tounge weight to make it squat. The one trailer at work we needed the forklift to get it on because it wouldnt jack up high enough to reach my 3" drop mount.
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
Seriously doubt you will need the anti sway hitch if tongue weight is only in the 5 to 600# range. That said, I tow a 5'er with over a 3200# pin weight and is amazingly stable. I would be surprised if you have problems. Just make sure your ball height is correct. My thoughts.
TWILLIAMS9
TWILLIAMS9
Ball height is going to be the issue I feel I am going to run into. I'm guessing I will need a 10" drop.
Birddog
West Palm Beach, FL
My truck stock was on 17's with 31" tires. Now I'm on 20's with 35's. I used a 10" drop and everything is perfect.
Reply from, I'm a Tapatalk junkie
TWILLIAMS9
TWILLIAMS9
What size lift are you on? I have an 8 inch lift but the rear sits about an inch lower than the front. I also have 20's and 37's. Maybe a 12" drop?
Birddog
West Palm Beach, FL
I have a 6" suspension lift but I only went up 4" in the back so is be level. I measured my ball height before so I already knew I needed a 10" drop. It's perfect.
gville35
