TPMS Issue
Bnip1
I have a 2008 2500 SLT 4X4 6.7 Cummings. I've had ongoing TPMS indication problems. Initially I was told by a dealer that the wheel sensors needed to be changed. They replaced the wheel sensors with factory Dodge sensors which were rubber vs the metal version that came out of the wheels that the truck originally cane with. I was told that the new sensors with the rubber valve stems were the updated replacements. After these new replacements, just like before, I would drive the truck approximately 50-60 miles and the TPMS light would begin flashing. Repeated trips to the dealers resulted in changing out the wheel sensors again, under warranty this time, and replacing both the front wheel well antenna/signal transmitters, and the module that goes around the ignition key. I believe it was called "WIN module". The problem persisted and now after several months when starting the truck I get the chime and the flashing TPMS light and then about every 20-30 minutes the light will flash with no chime and continue for the remainder of my drive.
Any help with this issue would be greatly appreciated, thanks.
HemiLonestar
Navy Badge Coast Guard
MD
Cummings lol
It sounds like the so called replacements aren't backwards compatible with the truck....I'm guessing the old ones are long gone (for part number comparison)?
joshhhh
