TPMS problems after new wheels
jeffrey5679
Lake Stevens
Hemim 5.7
Installed new wheels with oem tpms sensors. The sensors are not pickup 1 sensor. Weird thing is that the wheel keeps changing locations. It won’t read 1 sensor for a while then after awhile it will read that sensor and not read another. any ideas?
kmrtnsn
Ventura
What wheel? Larger in diameter? Extreme difference in stem location from OEM? Did you reuse the old sensors or buy new ones? Either the sensors are not correct or the reader isn’t picking them up.
J
jeffrey5679
Lake Stevens
Hemim 5.7
4 new oem sensors. They all will connect, only 3 at a time. Keeps switching every so often which one is out. Wheel diameter is only an inch bigger (33’s). Had the tires on for 3 days. Does it program 1 wheel at a time?
kmrtnsn
Ventura
Mine have always popped right back up. Once it took driving about 50 miles but then they were fine.
PoMansRam
East Aurora NY
Are you sure they are the correct part number OEM sensor? They changed a few times over the years. Up to 2014 is one sensor p/n, 2015+ is another. Not sure what the 5th gens use. I assumed it was the same as 2015+.
FWIW, I have an OEM set out of a 2015 in my winter wheel/tire set that pop right up on my 2019 classic.
J
jeffrey5679
Lake Stevens
Hemim 5.7
They’re the right ones. 68293199 AA 433 MHz 2020 ram DT. Just weird that they all work, but 1 seems to be missing and the location changes.
Rgesse
