TPMS values
moregrip
What tuning option, if any, allows you to modify the air pressure parameters so I can run 32psi in my rear tires without my dash light energized?
07MegaCabRam
Chandler, Arizona
6.7L CTD
Thankfully, I have a friend who is a Chrysler tech and he changed mine before the update from FCA.
Unless you have a Aultel- it can't be done. The tool is about $1500. I know someone in Arizona that has bought one and had made his money back (or I think he should have by now) charging $50 a truck. Takes 2 minutes.. but you need a PIN from the dealer to access the BCM.
MADDOG
Living in a Firepit
Yeah, if your dealer has updated his diagnostic tools, FCA's current tool software prevents the tech from touching that portion of the module and they can't change the pre-programmed values.
No aftermarket tuner touches that area of the module however as 07MegaCabRam mentioned, there is a tool made by Autel (MaxSys MS906 - currently on sale at just under $1,000) that can do the TPMS reset.
I do have a reset procedure that can be used but it only works on prior versions of the FCA tech tool. You'd have to call around to see if any dealers in your area still has a prior version.
M
moregrip
thanks for the info....not many options that's for sure!
