Tps?, iac?
dixierider
Alrighty, new here so bare with me. 02 4.7 1500. Running low on gas, (and by low I mean almost on fumes) Stopped, topped the tank went to pull out and he (yes my truck is a boy) started sputtering like a ****** Died SEVERAL times on the way home. Would not stay running unless my foot was on the gas. Ran code, came back misfiring on multiples (#2 and #4) Pulled/ checked-no issues. Wanted to check dist/rotor, boyfriend said it has coil packs (man I miss my 89 'Kota!) Anyway, checked vacuum lines etc. Been reading up (mostly here) and thinking TPC or IAC. Question is - Is there another way to tell if either is bad without just going out and replacing them? Or is that possible. Any input would be appreciated. Thanks in advance.
quietpeen
2021 TRX
Hellcat
welcome to RF. Somebody that know should chime in
D
dixierider
Hope so. I really dont like these newer vehicles. I prefer pre 1975. In those its only fuel, fire and compression. I hate sensors and relays and crap. Will fell better when I get around to getting a real service manual for it.
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
Technically your truck is a 3rd gen (2002 2nd gens were 2500 and 3500). We will leave that to the moderators. =)
Anyway...maybe something got sucked into the fuel pump blocking the filter enough to cause misfires. (maybe not enough pressure getting by?) Just a guess. Good luck!
Okiespaniel
Work, Shop, Computer
magnum, 5.9
You should never run these trucks below 1/4 tank.
It runs **** into the fuel system and injectors and causes the pumps to overheat, long term damage.
D
dixierider
I know I shouldnt run it low. I dont usually but**** happens. I put a new pump and filter on it the first week in November. Just put a new tps and idle control on it about 30 minutes ago. Its running better (as in a little smoother) but still stalls at an idle. That was 110 bucks down the drain. =/
Okiespaniel
magnum, 5.9
If you're still getting a missfire code I would have the injectors tested in those cylinders...they may be plugged. Mayben a bit of Chevron or Lucas Fuel injector cleaner would help.
MADDOG
Living in a Firepit
6.4L HEMI
One other thought...did you get the gas cap on tight after it was fueled up? A loose cap will let too much air into the system, causing just the symptoms you describe.
The fuel cap gasket will also fail and cause this condition to occur.
