Tradesman steering wheel upgrade
Becks
Mn
I’ve searched high and low and I see that you can order an upgrade kit from allmopar to get steering wheel audio controls, but my steering wheel looks like the last owner had a hook for a hand and beat the crap outta it.
I’ve seen where guys have said they just plugged in a big horn or Laramie steering wheel and it just worked and I’ve seen people that say a harness or module is needed.
I have the basic 5” radio without compass.
Has anyone got a pulled steering wheel and got the audio controls to work?
Thanks!!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks!!
The Audio controls should work with any RAM. Features like Heated steering wheel require more parts and programming though...
B
Becks
Mn
I just miss those two buttons on the back since going from a Laramie to a tradesman. I didn’t think it would be a big deal but I miss them.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
I swapped a Laramie steering wheel into the 2015 Tradesman I used to own. It's a straight swap, no harness or module was needed for the radio control buttons.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
This is what I wanted to do but if I can get a better condition steering wheel it would be a win win.
THey do sell the buttons and harness as a kit, but it can be cheaper to just swap wheels...
B
Becks
Mn
One more follow up question, as long as it’s 4th gen I should be good as far as 1500,2500,etc? I will try for a 2500 but I imagine 1500’s are more common.
mikeru
Super Moderator
2020 Limited
Yes, you'll be fine. But you may need to swap your buttons over to the new wheel. The steering wheel I used for my 2015 Tradesman came off a 2015 2500 Laramie. I did have to swap the buttons from the tradesman wheel over to retain the shift limit functionality but it worked just fine.
Ghstrdr95
