Trailer Brake Controller Question
caltx01
Tyler, Texas
Pentastar
Should a trailer brake control module from a 2015 RAM 1500 function properly in a 2014 RAM 1500? I installed such a unit in my 2014 RAM and it shows as not connected. All BCM settings are confirmed correct. All connections are good.
If this configuration is supposed to work I suppose I am looking at a bad control module.
Thanks in advance for any guidance and advice.
Amoinor
NY
If you installed the brake controller yourself it will need to be activated my a dealer, or as I did myself with alfaobd for the BCM to use the feature.
If it's showing trailer disconnected it's working unless it's saying that with a trailer connected, if that's the case check the fuse in the PDC.
Check the part# of the ITBM, looking on allmoparparts.com it lists:
2013/14 = 82213474AB
2015 = 82214492AB
2016/17/18 = 82215040AC
akordboy
US
2015 = 82214492AB
It appears this is for the receiver, not the module
Sent from my SM-N975U using Tapatalk
akordboy
US
Nevermind, I see it's for both
caltx01
caltx01
Tyler, Texas
Pentastar
2015 = 82214492AB
Well, after I returned the 2015 module and sourced the correct 2013/2014 one my trailer brake controller works great. I learned my lesson about assuming all parts 2013 to 2018 are interchangeable!
Thanks again to crash68 for steering me in the right direction.
stevenmicheal
