Trailer brake controller
Punisher123
Canada
hey guys I’m buying a new trailer but I need a brake controller, my 2019 Ram express crew didn’t come with one. I’d like the oem one but they want $500 for it. What aftermarket brands are the best
Or should I just go oem?
CamperMike
Peoria, IL
OEM can be bought for $155 and install is not bad. Dealer can flash it probably under $100. I paid $80 for our local dealer to set it up.
NapaRam
Napa CA
3.6L V6
$500 seems way too high for an OEM TBC unless the 5th gen are really different. You need to flash the truck or get alpha and do it yourself.
chri5k
USA
Diesel
I have had both a Tekonsha P3 and the OEM in my 2016 2500 CTD. The OEM did not put out enough current / voltage for one of my trailers to provide enough stopping power. I had to install the P3 to get enough current /voltage for that trailer. The new trailer works very well with the stock controller. I did find the P3 was finicky with the new trailer to find the right adjustment to keep the trailer from over-applying the brakes which stops a bit jerky. The OEM one with the new trailer provides very smooth stops.
tron67j
Maryland
Also had Tekonsha on a truck and a van, both worked very well. Hitch installer did it but don't remember price. Wasn't high enough that I kept it in my head as a bad memory.
Purplert
Oem ish for like $150 on either eBay or Amazon... install it yourself.. then pick up Alfa and flash it yourself and save yourself a bunch of money
Punisher123
Punisher123
Canada
I’m in Canada. Dealer wants 500
Amazon Canada wants 400
We get screwed here
CamperMike
Peoria, IL
Try Ebay for the controller... I don't know what options you have in Canada but I'd at least check there. Amazon was quite a bit more when I ordered mine.
pacofortacos
you could try car-part.com
search under computer box not engine.
Works in Canada, or US wreckers may ship to Canada or if you are close to the border maybe a fellow member could help you out and meet at the border.
There is a used one off of a 2019 for $100 @ http://flowersautowreckers.com/inventory/main-search/
A dealer in Ohio sells them new or new takeoff (?) for $155.
Jendsley06
Southern Illinois
I bought this one and put in myself. Programmed with alfaOBD. Extremely happy with it. Pull two different trailers with it. It keeps a trip odometer for each, integrates the traction control and has away control in it somehow too. And the plus of not having a box in the way to hit your knee on every time you get in or out of the truck.
82215040AB 2016-2017 RAM 1500,2500,3500, 4500 Trailer Brake Module https://www.amazon.com/dp/B073PLFNT5/ref=cm_sw_r_cp_apap_EgESEdpFSWtDb
BobSacomano
North Texas
3.6L V6
I'm going through this same thing right now. Thinking about getting a camper. Obstacle: I won't patronize the service department at the local Dodge dealership (you wouldn't believe the story), so I called the Dodge dealership 50 miles down the road... They quoted me two options. Aftermarket brake controller for $180 installed, or OEM controller installed for $375.
Not sure which I'm gonna do.
Razzman
NorCal
2020 Limited CCSB
Is that what you have? What was the install and setup like?
No mine came with the factory setup, wife works for a trailer dealer and they install these sometimes. Real clean setup, doesn't seem too involved to install.
