Trans won't go into manual mode
scHemi
2009 RAM SLT Crew
Thoughts guys? I was coming home from work this evening and wanted to use the manual mode but it wouldn't work. The trans temp was not registering on the dash as it was below 104 degrees
Is this a fail safe and supposed to happen
NYCruiser
Yonkers, NY
Your trans temp doesn't register below 104 degrees? My engine oil won't, but tranny definitely runs a lot under 104.
S
scHemi
2009 RAM SLT Crew
I think it doesn't. Like the gauge starts at 104
NYCruiser
Yonkers, NY
Wow. My tranny runs cooler than 104 a lot of the time. I think if the truck isn't warmed up some tranny features are limited, like TC lockup, and gears get held a little longer. Not sure about locking out manual mode.
S
scHemi
2009 RAM SLT Crew
I usually see 150 on my trans temp after I've been driving a while
NYCruiser
Yonkers, NY
I don't think my 14 tranny runs that warm without towing. around 120, I think. It definitely reads like 40 when I get in and I can watch it warm up.
My engine oil reads 104 minimum and won't register anything until it gets past that.
S
scHemi
2009 RAM SLT Crew
yeah my truck reads <104 until it reaches 104 then it registers on the graph. I usually see after driving around town and whatnot for a while 130 to 145.
It was crazy cold here and its getting worse i just don't want to think about something being broken. i hope the manual mode is just unavailable due to trans temp not being above 104
NYCruiser
Yonkers, NY
Actually paid attention this morning driving to work in snow with 4WD engaged. Tranny stayed around 110 once warmed up.
S
scHemi
2009 RAM SLT Crew
and did the manual mode work? can you try it like 10 minutes into driving because thats all my commute was home last night, and the trans never showed a temp
NYCruiser
Yonkers, NY
Yes. Manual mode works immediately when truck is cold. It will hold gears a little longer until it warms up, but does let me go into manual.
S
scHemi
2009 RAM SLT Crew
Hmm interesting
S
scHemi
2009 RAM SLT Crew
Well after driving more then the 10 minute commute home I was able to get the transmission above 110 degrees and the manual mode works like normal
NYCruiser
Yonkers, NY
That tranny has to be different than the one in my 14. Do you have an owners manual for it?
S
scHemi
2009 RAM SLT Crew
I do have the manual and there isn't anything in it.
NYCruiser
Yonkers, NY
Perfect. LOL. I'm surprised other 09 owners haven't chimed in on this thread.
NYCruiser
Yonkers, NY
I looked at your owners manual online and saw this note. I wonder if this means you can't manually control it until it warms up:
NOTE: If the vehicle is started in extremely cold temperatures,
the transmission may not shift into Overdrive
and will automatically select the most desirable gear for
operation at this temperature. Normal operation will
resume when the transmission fluid temperature has
risen to a suitable level.
S
scHemi
2009 RAM SLT Crew
That could be it. It was 8 degrees it's morning lol as you know
NYCruiser
Yonkers, NY
Yeah. The later model tranny's may just function better at lower temps. I know there is some new tranny warmer feature that uses engine coolant to warm the tranny up faster.
