transfercase diagram
Brandon-w
Yukon
2015 Ram 1500
Oh dang! That woulda been a nice spot too!!
Sent from my SM-A530W using Tapatalk
chrisbh17
Yes Im slowly learning a lot of the switches we think are switches are just black boxes (see: ignition key switch, ignition push button, etc)
Makes sense.....use the same mounting and case with just a different PCB inside, just like the button plate for heated seats, park assist on/off, etc.
Hemi395
Cape Cod MA
So they're basically more of a module than a switch?
chrisbh17
Yep. Like the ignition key or button, just a black plastic box that mounts up with 4 screws. Same exact connector, just different innards.
Im sure somehow it saves FCA money on top of increasing service revenue (because replacement is easier than refurbishment)
Brandon-w
Yukon
2015 Ram 1500
That would make sense. If it's just a pcb board canbus can just measure resistance when button is pushed and the pcm/bc. module holds that command until pressed again or another command is pressed. That's why when traction control is pressed once it turns it off and when it's held it shuts it completely off. Or that's how my brain understands it anyways.
Brandon-w
Yukon
2015 Ram 1500
I know! I was really looking forward to having a "lock" switch there...
Could still use the stick on one there? Not as clean but still functional.
chrisbh17
If you have the useless square cubby on your dashboard, this might make a good use for it. Mount the switch in there, or even under the little rubber mat to hide it.
Brandon-w
Yukon
2015 Ram 1500
If I didn't have switches in my console I'd have put mine right below the selector on the console.
Brandon-w
Yukon
2015 Ram 1500
Yeah like what is the use for that cubby? I don't have anything that will fit or stay in there with my driving for that matter.
Hemi395
Cape Cod MA
It's like the designers had 1.2 cubic inches left over and they were like "eh make a little storage spot that no one will ever use"
chrisbh17
Just need someone to 3d print a plate that snaps into it, then mount your switch.
Sent from my Nexus 6P using Tapatalk
Brandon-w
Yukon
2015 Ram 1500
I'd like to get a 3d printer but I can't afford that.
Brandon-w
Yukon
2015 Ram 1500
Looks like I have alot of work to do. Just got the connectors! ca0fa8723e85a8db0ae692c816f3f66e.jpg
Hemi395
Cape Cod MA
Hey @Brandon-w did I see a post of yours a while back that showed a pic of your switch in the access panel on the side of the console?
JustinRam1500
