Transmission impact noise
Auckland, New Zealand
Hi everyone:
When transmission downshifting especially from 4th to 3rd and 3rd to 2nd , sometimes 2nd to 1st, it has impact noise, not huge but definitely noticeable. It’s happening from new now 5000km, not getting worse. Do I need to check or do something?
Thanks
I'd check if there is any slop in the driveline to the rear axle. Might need to lube the driveshaft splines, make sure to mark the driveshaft when you separate it so it can be reinstalled phased properly
Power Wagon NZ
Thanks . But I am sure it’s from transmission not driveshaft. Once the transmission oil temp reaches 75 degree it’s much better.
akguy09
Ellicott, Colorado
My trans is cluncky when downshifting from 3rd down. Sometimes into 1st is a little more noisy
Power Wagon NZ
After more test driving. I have found it happens most time when downshifting from 5th to 4th. An impact feeling and noise can be heard from cabin just like shifting impact. Sometimes it's very smooth but sometimes feel bad. Another thing is if I give a little bit gas immediately after downshift from 5th to 4th then can definitely feel the impact every time.
Have checked driveshaft didn't see anything wrong. I would rather believe that the ZF transmission is just like that.........
It's new truck, please don't have any problem......
