Spencer0526
I have a 13 ram 1500 5.7 hemi 4x4 with the 65rfe trans and about 2 weeks ago I was on my way home driving normal and the trans started stuttering and slipping it threw codes so I drove it home and used my Diablo tuner to read codes it read codes p0734,p0735, and p0933 I looked on here and found people saying it was clutch pack instead of changing clutch pack in trans I went and got a different one cause it was cheaper anx what I can afford before I got trans I tried replacing the hydronic pressure sensor and the trans fluid and filters it didn’t fix problem I just finished the trans swap last night and got everything back in and everything used the new transmission filters and replaced trans fluid with new and it’s still doing the same thing it’s taking off fine but once it shifts to second gear it speeds up then at about 30-40 mph it’s like trans slips and acts like it’s in nutral if I give it more gas eventually after I basically floor it it kicks back in but only goes to 50mph and starts redlining and bouncing off rev limiter at 6500rpm I have a hemifever custom tune but shift points are set at 6200rpm I had a local shop hook truck up to there reader and it read that it had low fluid pressure I made sure it had enough fluid and everything I’m at a loss currently I just bought a can of killer kleaner and once I get back home I’m gonna try flushing the trans cooler any help would be greatly appreciated sorry for the long post thanks
