Transmission Jerk
RetiredTennisPro
North Augusta
I have had a new 2022 Ram Big Horn Hemi 4 X 4 for about 3 weeks now. I love everything about it so far. My driveway is slightly downhill. I have noticed when I pull into the driveway that the transmission bumps a bit right before I come to a complete stop. Is that a normal function of the 8 speed transmission as it gears down going downhill. Does anyone else have this issue?
BigLazer4u
North Carolina
Cummins
I assume this is going up hill at a low speed? Before parking.. yes my 2019 did that as well.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
It's not something that I've noticed. But maybe I'm not experiencing those specific driving conditions that are causing it to happen on your truck.
Maxum
Canada
I have a 2021 that does this as well. Still not sure if it's transmission or brakes causing it in my case. Seems to be a little.more noticeable now than last year though. 1st gear is pretty low on these and depending on what gearing you have, will make first even lower. I don't seem to have any other issues in any of the gears and I don't always feel it in first either, but usually when I am noticing it, it's on flat ground as well pulling from a full stop to go. Almost like it's going right to 2nd immediately when I press the gas.
DJack
