Transmission not shifting into drive
Wayne75
Hi Guys,
I am new to the site. But am very pleased to see the wealth of information available. Thank you for providing this forum.
I have an issue with my 2009 1500 ram 4x4. 6 speed automatic transmission. All of a sudden It started to bypass the Drive gear and went right to the manual shifter but even then it stays in 4th gear only. It won't shift down or up manually. It goes into neutral, reverse and park normally. I should note that over the last couple week I have noticed it hard shifting a few times here and there as I've been driving. Does anyone have any idea if I need a rebuild? Or could it be something else. Below is a link to a short video I made demonstrating the issue. Any advise would be greatly appreciated. Thanks
http://youtu.be/mATBCSfyi2M
ramdude916
sac
Mine 2013 is in the shop as we speak getting the shift solenoid replaced. Threw a code p0750. Same symptoms.
Sent from my KFTHWI using Tapatalk
Hemi395
Cape Cod MA
That looks like limp mode from the video. You can try to pull the negative battery cable off to reset everything but usually the transmission goes into limp mode when something is wrong inside the transmission...
