The foil idea sounds like the ideal solution but, Dawn and water are fabulous for breaking down grease or oil.
Any of the experienced dive charter boat operators always had a bottle available for those divers who found oil in the shipwrecks.
I've cleaned up dive buddies, so I know it works quite well.
What do you think they use to clean up wildlife during oil spills?
I recently had a theory. So, I tried it. I was replacing GDI injectors on a 3.3L V-6 engine in a late model KIA. This vehicle had the usual intake valve carbon deposits, and those deposits were heavy.
So, I grabbed my equipment and commenced to blasting the carbon deposits with walnut shell media.
Problem was, the raw gas from the injector failure had made part of the deposits a thick, gooey consistency, such that when I blasted the first 2 cylinders, I got a nasty sludgy mix that made a difficult mess to contend with.
After finish-cleaning one cylinder manually with brake cleaner, the results were so-so, at best, and the fumes from the chemical overcame me, so I finished the first cylinder with a dual element respirator rated for chlorine and ammonia gas.
I thought to myself that there might be a more "eco-friendly" not to mention salubrious way to accomplish cleaning the remaining 5 cylinders. It "dawned" on me (pun intended) to try soaking the remaining cylinders with that Dawn Platinum cleaner, so, I tried it.
I allowed the Dawn to soak overnight, and the next morning, I was flabbergasted that the remaining carbon in the other cylinders had dissolved to the point that all I had to do was clean the mess up using paper towels to soak up most of the solution, followed by a little bit of using a pick on some small spots and a small rinse of water.
The cylinders all looked brand new, I finished replacing the injectors, and all is well! Needless to say, the experiment worked exceptionally well. To me, the use of something less dangerous than the chlorine based chemical or an alcohol based chemical is a huge win for my health!
PPE and hazards aside, it was WAY cheaper, too. And Dawn isn't a fire hazard, to boot.
BTW: The NIH report on tetrachlorethylene is pretty sobering. Boring to read, but succinct.
