transmission shift hesitation
Larry Jamison
Tacoma. Wa
I have a 2011 545RFE transmission and I have a slight shift hesitation anyone else experience this. Fluid level is correct.
Replacing valve bodies on the 545 should be considered a maintenance item at this point. For sure you have crossleaks. You can do this yourself if you can drop the pan, all all you need t25's torx bit.. The question should be do you need solenoid with VB. drop pan and 2 filters takes 8 quarts, consider metal thread upgrade, only use OEM sump filter but you can use synthetic canister filter there are threads on all of these use search. Bottom line very fixable with minimal cost, consider moving to redline c+ as well, great upgrade for rfe.
KAKA
