- Nov 5, 2016
- 8,011
- 22,697
- Location
- Maine
- 2015
- Pentastar 3.6 V6
2015 Quad Cab 4x4 Pentastar Motor 3:21 gears 8 speed transmission
What should the average temperature be ?
Mine seems to stay around 120/130 when it is below 32 and below ( Has not been above 32 yet )
I can drive 20+ minute at 60 mph not much a change !
If I park and idle the temp will go up and stay in the 160+ range ( I believe normal ? )
Coolant will be at the normal 190+ range
Is there a transmission cooler ?
Is the temperature controlled by a thermostat or sensor ?
No codes and runs fine, Shifting seem to take a while going from 7 and 8th
D you think it needs a Transmission reflash ?
would disconnecting the battery do anything ?
AM I missing something ?
Am I over thinking it ?
FYI I am now Gear Head just a Putz that is curious ! lol
