Traxda 3.5”front/2”rear kit anyone used this?
Lkw88
Has anyone used this Traxda lift kit on there 6.4 yet? I was wondering if it’s a solid option or not.
22hemi13
Tucson AZ
2014 2500 4x4
Never heard of em. That said they seem to be an America made as stated by their website. Oddly enough their located right down the road from where my wife works. I’m not a fan of spacers but I wheel my truck. If it’s a street truck and just after looks. For that price give it a try but spacers and these heavy beefy hd’s seem like a receipt for disaster. Just my .02
Dmopar74
I don't see any mention of drop pitman and track bar brackets. The axle would be severely shifted to the drivers side
Lkw88
Lkw88
This kit uses radius arm drop brackets and spring spacers to lift your truck without changing the ride. The radius drop brackets make sure the caster is at factory levels so that the truck drives straight - not all over the road like lesser designs.
In the rear we use the largest coil spacer that we have ever built, to work perfectly with the new Ram coil spring rear suspension.
No cutting, drilling or modification is required on the truck. The kit can be removed and the truck returned to stock if desired.
This is all the information they give on it
olyelr
Kewadin MI
Shock extenders with no bumpstop drops? RUN LIKE HELL. And yea, your front axle will be off center like crazy.
olyelr
Kewadin MI
If your not looking for any performance enhancements at all, I could see the kit working. But at minimum you should still buy an adjustable track bar or a kit to lower the factory one (along with a drop pitman arm), and bumpstop drops for the shock extensions.
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
For a few dollars more you could do Coils and shocks from Thuren. Better ride for sure and you can build from there.
Lkw88
Lkw88
Sounds like this kit is not the way to go then lol thanks everyone
Lkw88
Lkw88
You got a link for the Thuren setup?
