Trinity tuner, quick question
HookEm Hemi
Lavon, TX
Has anybody calibrated their speedometer w/ the Diablo Trinity? I need to adjust for my 35x12.5x20 tires, but don't want to get in there and screw up the wrong settings. Also, I keep reading about "boosting" the throttle to make it more responsive. Can anybody tell me how? Thanks!!
popcenator
Omaha, NE
It's simple to adjust the tire size, just go into Modify Tune or even Quick Adjust and put in your tire size. To boost the throttle, go down to Throttle, then up it anywhere between 0-20%. It'll just adjust the sensivity of the throttle reducing the sluggishness a little. I've had mine at all levels and am back down to 5% ATM. You'll just have to play with each and figure which works best for you.
H
HookEm Hemi
Lavon, TX
Thanks!! If I go into "Modify Tune," will I have to make the same change for each tune I use? OR if I do it on one will it make that adjustment and I won't have to worry about it when I change tunes?
namccanna
Auburndale, WI
5.7L HEMI
Changing tire size on the Trinity is super easy. All changes you make on the tuner kind of walk you through the process. If you reach a point where you're not sure what you're doing... it always gives you the option to back out and cancel the changes.
As for the throttle boost.... I've set mine to the max (20%) and haven't had any reason to change it to anything lower.
