Truck leaning towards rear driver side after Bilstein 5100 install
Hbrichman
Orange County, CA
Hey everybody,
Just leveled my ram with Bilstein 5100’s front+rear and noticed today that my truck has a slight lean now towards the rear driver side. The front sits evenly at 40” on both sides, but the rear driver side sits about 1/2 or so lower than the passenger side. It’s noticeable but not too bad. Anybody else experience this after installing Bilsteins? Is it normal? Just trying to see how common this is or if something went wrong.
Thanks!
RVGuy
Alberta, Canada
Every Hemi I've seen around here has that lean.
We've started calling it the Hemi lean. It's really noticable in our work parking lot because everyone backs in and the lot has a slight slope to it that magnifies the lean.
So check me off for "It's normal".
Hbrichman
Hbrichman
Orange County, CA
Thanks for the replies, figured that might be the case but just wanted to double check
BOWERSFJ
Uniontown OH
Full 225 lb tank of gas, and a 200 lb driver, and you’re level again
Hbrichman
Hbrichman
Orange County, CA
Except it leans on the driver side, not passenger side. Wouldn’t that make it worse? Lol
22hemi13
Tucson AZ
2014 2500 4x4
Rams and their lean. My 2500 does it too and the caster adjustments are correct. I’m going to put a 1” spacer on the driver rear and call it a day.
BOWERSFJ
Uniontown OH
My bad ... I thought you had the normal driver high lean ...
Gary2
S Jersey
Like most I am also driver side low. Jeep TJ 3/4" spacer got it closer. This raised left rear and slightly lowered rt front .
JB1
Houston, Texas
Always take “before” measurements and write it down.
olyelr
Kewadin MI
Yea, installing the front setup should not have changed the rear height at all, especially if the front is level side to side. The different heights out back were probably there before you leveled it, you just didnt know it without measuring.
22hemi13
Tucson AZ
2014 2500 4x4
Holy **** yours is 1” off?!
Yeah lol. Between my fat ass full fuel tank and softer springs it’s really does lean. I even load water and gear mostly to passenger side to help haha.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Most OCD people trim springs a bit on the passenger side.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Or put a spacer on drivers side.
Only issue with that is you have to pull the front struts on the half tons, where a spring compressor allows a trim with the assembly still bolted in. A between coil spacer might give you a little boost, but it will change the K-value of the spring.
olyelr
Kewadin MI
Im talking about the rear, the side that is low. A spacer below or above the spring. Not sure k-value is...
ChevySlayer69
Maine
Mine doesn't have a lean. is it possibly you pulled the rubber isolator off one of the rear springs?
olyelr
Kewadin MI
You had a shorter and a longer spring right ? where did you put the shorter one ?
From what I gathered from his original post, he only leveled the truck up front and changed shocks out back.... as in still has stock springs out back.
My guess is the truck still has the same lean it always did, he just didnt realize it until he took a tape measure to it.
