Truck lowers after closing door every morning
tul9033
OK
2019 Ram Limited
Every morning I open the passenger door and place my stuff in the passenger seat. As I walk around to the driver side I can see and hear the truck lowering the air bags. I have the truck height set to Aero.
Any ideas why it's doing this? I thought maybe it was an entry setting, but why lower after the door opens and closes? Just doesn't make sense to lower after entry. The ride height setting is never changed manually. I am using the handle to unlock (no fob). I haven't heard it pump the ride height up after getting out the evening before, yet it's lowering after morning entry.
Thanks for any insight.
Jus Cruisin
Gearhead
Metro Detroit area after 28 years in Florida
2019 Limited 4X4
E-torque hemi
You sure it isn't raising to ride height after sitting. If the temperature drops the truck will settle some and when you open a door, you "wake it up" and it finds the programmed height.
Nationaljan
Holbrook
I believe there is a setting. To drop automatically when getting in and out. Called exit/entry height. Believe you can turn it off. So it does not do that.. don't take that to the bank I thought I read that somewhere.
