Tune to disable MDS?
14RamRod
Hello newbie on this site. I own a 14 RCSB and hate the MDS just like I did on my 07 yukon I used to own before this one.
I got rid of the cylinder deactivation with a tune on the yukon. Anyone recommend a certain tune?
Statcher1
Kentucky
Either bullydog or diablo can disable MDS.
14RamRod
14RamRod
Thanks Brad. I see you have the bullydog do they have in person tunes or are they via autocal?
Statcher1
Kentucky
Bullydog is all canned tunes. I love mine it has really woke the truck up.
O.R.T.
Wessyyydddeee
Do you have the tow-haul package with the magic button and the 6speed?
Pressing it turns off mds while allowing more rpm's to go into the shifting and all "6" gears are active. Just keep in mind it locks out 5th and you actually want the overdrive if on the highway for extended periods to keep the transmission fluid cooler.
14RamRod
14RamRod
I do have the tow package with the 6 speed. Are you talking about the tow/haul button? I haven't tested it out yet guess I'll try it today.
Thanks guys just want to get rid of the awful sound it makes when active sounds like **** IMO.
O.R.T.
Wessyyydddeee
Again, just don't leave it on while doing long drives or anything at highway speeds or you'll cook the trans. Around town is fine.
loveracing1988
Clarkston, MI
If anything it would make the transmission run cooler. That is one of the reasons it disables overdrive, to extend the life of the transmission while towing. It might make your engine run a little hotter from turning more rpm's but that will be it.
Blainepaul36
South, LA
I agree about it sounding like crap in MDS, but if you manually shift it into 6 gear it disables it until you take it out of drive. :happy107:
Steve58
