While driving home from work I noticed the temp gauge was a bit higher than I've seen. To be fair it's the first warm day since I've owned my '97. Engine is 5.2 L. Only odd thing about the cooling system that I've seen is that there's two ports on the passenger side where I assume transmission lines would go. There's nothing on them and trans runs through trans cooler only.
Temp dial split the second 0 in the 200 mark today. I'd estimate that's 210 to 215? Is that normal?
I haven't flushed coolant system but it is flowing. Heat works fine and there's plenty of fluid. Fan on the engine of course spins too.
