U1424
BigWhiteSnake
Morris Plains, NJ
5.7L V8 HEMI MDS VVT Engine
Cruising down the NJ Turnpike today at 70 Mph. All the sudden the truck went into limp mode. Engine light, traction control, and a red light I couldn’t identify went on as well as a message about the brake controller. The info for the U1424 is scarce, but it has something to do with the CAN receiving a bad signal. Anyone have any ideas?
Fast69Mopar
U1424 can be a trick DTC. The diagnostics for this code are very vague so here is what I do...
There is a TSB that refers to this DTC.
TSB 18-021-17 is applicable to the
2013-2015 DS trucks. This TSB is for performing a flash update to the PCM with the latest software.
I would give your local dealer a call and give the service advisor your VIN to see if your truck is still withing the 8/80 Emissions Warranty, depending on year and mileage of your truck.
Worst case scenario you pay an hour of labor to have them flash the PCM and be done.
  • 18-021-17.pdf
