Uconnect ra4 navigation issues
Hockeygod
New York
Hello I have recently installed a Uconnect RA4 8.4
When I am driving the truck, the map does not refresh on it as the truck is in motion. I tried everything on it Updated Software, etc.but I can't figure out what is the problem. The map will refresh (every 1-2 minutes) and show the right location but then again it will stop. The compass shows the right direction and it’s getting signals from satellites it acts as if it’s behind my location about 1-2 minutes. Any help would be greatly appreciated thank you.
Hockeygod
Hockeygod
New York
Hello thanks again for your reply and help. I have software update 18.45.01 what map update should I use with this? Thanks again.
markabby
Monticello, Kentucky
2020 Limited
i'm not sure of the map update for that radio. you might have to look at the uconnect web site.
does your radio menu options have a gps reset option?
there's also another posting with the same issue.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I know that Gen 4 Ram
Navigation update map that you pay something like $140 for, comes with the Radio Update.
The last time that i updated was about 5 years ago, which is about the right time to update.
From 3 to 5 years between updates.
When i updated, it corrected the positioning of the vehicle on the Map
If you can find a Free Map Update, you would be good
I know that they are available
This is the Official Site for 2014 Rams
GTyankee
3.0 ecodiesel
Enter your VIN to find out if you have the most current software update
By the way, IF you do find a newer software Update
let us know, i know that i have the same version that you have
Hockeygod
Hockeygod
New York
Thanks again for all of your help. Does anyone have the latest map update?
Hockeygod
Hockeygod
New York
Does anyone think it could be the sierra wireless air card?
Hockeygod
Hockeygod
New York
I also talked to uconnect and they said a map update would not fix the problem I am having.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Uconnect says the maps for all vehicles 2016 and below are no longer available.
The maps (Garmin or HERE) are serialized and coupled to a VIN once activated after you do a voodoo dance. That being said, chances are finding a usable map is out there for free is almost zip.
Since they are no longer available thru Uconnect, seems as maps should be a free agent thing now and an aftermarket map maker should be able to supply them.
tron67j
Maryland
Know you just updated your radio, but you may want to consider a 8.4 upgrade from a 2019 or newer UAS unit out of a classic. Then you use your phone for maps and are never outdated. You can also use a UAQ which has navigation but then you are back to needing updates. There is a whole sticky thread about upgrading plus you need a harness that M²Mods in vendor section can sell you. I did the upgrade in my 2018 and best money I spent on my truck. Avoid 2018 UAS or UAQ as they had problems with the screens delaminating. My wife's vehicle has built in navigation and it can't use any of the new roads around us as well as new ones in areas we travel to.
bloup
Wasn’t there a procedure to calibrate the GPS by going in circles in a parking lot?
Thornback
Hemi 6.1
I installed Waze navigation on my truck. Waze is free. I also installed Google navigation. It's also free. Both work just fine. I put both apps on my c-phone and synched to the truck's Bluetooth.
Tom Piper
The Berkshires
Hi, I have the exact same problem with my 2014. I have brought it to the dealer at least 6 times and replaced the radio thru the dealer, all the visits and the new radio cost over a grand; no joy. Mine started when I upgraded the software. I've reached out Corporate customer service several times but again; no joy. If you ever find out how to fix this issue, I would love to know what it is.
