UDYSPWGN “Build”
buckeyexx
Ohio
2016 Power Wagon
I have a 2016 power wagon and Im curious as to what oil temp you were getting pulling your trailer. My coolant temps and trans temp are great but noticed when I pulled a 20ft cargo trailer that probably weighed 5000lbs total and my oil temp got up around 240 on a 65-70 degree day. I didnt feel like the truck was working all that hard and was pulling the trailer with ease in my opinion. I crossed a few small hills but really it was pretty flat road. Im thinking maybe the 35's and thuren level are working the truck harder than I think and wanted to ask someone with the same setup as mine what they are getting. Also I did have a 2015 6.4 that was leveled but on stock size tires and dont ever remember the temp climbing up like that and I towed much heavier loads than this. I know 240 isnt hurting the redline oil I have in it but seems higher that I was expecting.
Udy2554
Udy2554
Naples, NY
Sorry so long to reply! I’ve had temps go into the warning range once! Pulling about 12,000lb of a loaded Fury toyhauler! It was up a grade at very slow speeds following a bunch of trucks with trailers into a riding area!
Wheeling in low range locked I’ve approached some temps that made me nervous! That was 30,000miles ago!
At 58,000, so far so good!
buckeyexx
Ohio
2016 Power Wagon
No sweat! Thanks for the reply. I’m thinking either it’s due to bigger tires and the Thuren level or a partially blocked oil cooler. Even when I’m cruising on the highway and my rpms are above 2k it will run 224ish until I get the rpms under 2k. That’s completely empty no load behind me. Sorry don’t mean to put this in your build thread. Just curious from another truck with similar setup.
Udy2554
Udy2554
Naples, NY
Hmmm,
My first real negative experiences with the PowerWagon!
1: Passenger side exhaust manifold has been “ticking” at me for the last 4500 miles or so!
2: I’ve been feeling a “hum” at about 55-56mph for a the last hundred miles or so! The other day it became a vibration at 40mph or so!
Service appointment 7/22 at Friendly Dodge in Penn Yan, NY!
Just passed 60,000 miles!
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Bet they'll get you straightened out. Its just getting broken in
Udy2554
Udy2554
Naples, NY
To the dealer tomorrow! Exhaust manifold and transmission issues! I’m not excited about time constraints! Exhaust manifolds I’m told 4 days! Transmission issues…not excited!
Udy2554
Udy2554
Naples, NY
Whats goin on with the trans!
A couple little things.
1. For the last couple hundred miles, at 55-56mph, I’m feeling a “hum” in the floorboards! Cant hear it, just “feel” it.
2. I live on a high, long grade! Lately it’s been hanging in 2nd up to 6000rpms, randomly! AC on or off! In the pedal or not.
3. I was low about a pint of fluid. A little dark, but didn’t smell burnt.
4. And randomly shift a little “funny”?!?!
Anyhow, dropped it at Friendly DCJ. It’s in for exhaust manifolds. Figured I’d gave filters and fluid done! Normally I’d try it myself, but I don’t have the space to leave it on jackstands in my barn. Also, though tranny fluids is better than gear oil, I really don’t want to smell it in my “home” for a few days.
Btw, notice I’m trying not to yell? ;-)
olyelr
Kewadin MI
I did lmao! Good job lol
Udy2554
Udy2554
Naples, NY
As of Tuesday 23rd…
Passenger side exhaust manifold needs replacing…warranted.
Rear driveshaft needs replacement! 5-6 days for the part. Waiting to hear if covered by Maxcare Warr.
Fingers crossed!
Trans filters and fluid replacement I’m told $425!
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
As of Tuesday 23rd…
Fingers crossed!
THe drive shaft on my wife's jeep was covered at around 90,000 miles under max care many years ago. Hopefully yours will be too. Pretty crazy that the drive shaft going bad is even a thing. I remember thinking they looked pretty stout.
Udy2554
Udy2554
Naples, NY
Great to hear, that’s encouraging.
olyelr
Kewadin MI
Why would the driveshaft need replacement? Is it bent or something?
Udy2554
Udy2554
Naples, NY
I’m told a u-joint was coming apart!;-p
I feel a little like an idiot. I’ve had driveshafts come apart wheeling. I’ve had them twist in half like 2 Dairy Queen ice cream cones. I’ve heard the chirping of a u-joint ready to fail.
I never got underneath to check u-joints! I had myself it was transmission failure waiting to happen!
Anyhow…driveshaft and cracked exhaust manifold replaced under warrantee! $108.00 total cost!!! Max Care Warrantee took care of the shaft. Factory warrantee covered manifold. I was at 60,625 miles.
Friendly CDJR even washed the truck as part of their service. Excellent communication with Betsy the service writer, and Kenny the service manager.
I highly recommend Friendly CDJR in Penn Yan, NY. Check them out if you’re in the area!!!
Udy2554
Udy2554
Naples, NY
I may be losing, or already lost a lifter! Pretty decent rattle out of driver’s wheel well.
Pulled my empty equipment trailer to a job about a half hour away(23mi). Then, another half hour drive(28mi) to a parts supplier for a boiler cast iron heat exchanger. Then, headed home to grab a quick lunch. No issues, just a nice morning drive.
After lunch, started the truck to deliver the Heat Exchanger…quite the rattle! 12 miles to customer’s place, rattled the whole way. 58-61psi oil pressure, level is good.
On the way home, CEL came on!
Well ****!:emotions122:
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
That sucks!
Udy2554
Udy2554
Naples, NY
That sucks!
Yes it does!
Weather is changing! My other ride is a 2000 WS6! I do HVAC out of the PowerWagon! I may have to sell the car to finance a van to work out of! I can’t go without a truck for an extended time right now!
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Yes it does!
I would think max care would cover it. Do they do loaners?
Udy2554
Udy2554
Naples, NY
I’m sure it’ll be covered! The dealership that takes care of my truck really steps up!
Loaner, I’m not sure! I really need a van! Too many tools and service parts to be left exposed to the weather!
Marty424
