argroft
So I recently purchased a 2015 Ram 1500 Crew Cab and I wanted to upgrade the sound a bit. I thought a good place to start might be adding a sub (or two) under the backseat. What I would really like to know is, are the floor pans in the 2015 Crew Cab the same exact shape as the 2002-2005 Quad Cab? I have a box that I had made that has two subs and an amp already mounted in it. A couple seat spacers and some wire and I'll be mostly good to go.
Pic of the custom box from my 02':
IF the floor pans are different and someone can confirm, then who makes a good single/double underseat box that will fit a 10" Alpine type R? I have no interest in doing the fiberglass work again to build a new box.
On a side note, I happen to have an Audio Control LCQ-1 I plan to use to get a signal for the amp (and maybe some future speaker upgrades). Is it okay to tie into only the rear speakers, or do I need to tap the front ones for full range output? I have the 6 speaker, non-Alpine system with 8.4AN Radio.
Any help with any of these issues would be greatly appreciated!
