Unidentifiable squeaking sound coming from rear end
JDude
Staten Island, NY
I started noticing this noise a few days ago and its slowly starting to get worse (Video included). My truck is a 2008 1500 5.7 4wd. I took the driver side wheel off and looked around and I couldn’t find anything. Maybe someone can help or give some suggestions?
Thanks.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
Have you thought about getting someone bouncing on the rear bumper and you look and listen under your truck?
SYKRAMMAN
Banned
Jersey shore
06 Mega
Wheel bearings. Don’t let them go too long, otherwise you will oval out your axel housing and they are 900$ from junkyard.
JohnnyMac
SouthWest Washington
2018 1500 Laramie
3.0 EcoBurner
Does it happen only when accelerating, decelerating, coasting, or all the time? I had a U-joint once that made a similar noise, but only while coasting. When I applied power, or was slowing down on compression, it got quiet. But I also think SYKRAMMAN is probably on to something and you should check out the wheel bearings.
