Unsure what this is? Any ideas?
Canadianguy
Ontario
Unsure what this is? The pics aren’t the best but it’s a long piece that runs approximately the length of the tail gate. It’s situated under the tailgate and bumper. It also a few wires running off the one side. Any ideas?
Ohio5pt7
Ohio
Looks like a led light bar to me lol
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Ohio5pt7
Ohio
I assume you bought is used that's definitely what that is
Canadianguy
Canadianguy
Ontario
Yup, 2017. That’s what I thot it could be. Thanks
Ohio5pt7
Ohio
No problem
thkbaron
Minnesota
guessing it's wired into your running lights.
Canadianguy
Canadianguy
Ontario
Just had a quick look underneath. They’ve tide into some wiring for sure. Gonna have to have a better look once the rain stops!
Ohio5pt7
Ohio
My guess is they may have wired it in with a curt harness. Wires will likely run into the back of your trailer plug
Canadianguy
Canadianguy
Ontario
Gonna remove it. I’m assuming it shouldn’t be an issue.
Ohio5pt7
Ohio
Nope just be prepared to deal with the double sided tape. Its gonna be a pita to remove in such a tight area
rwhjr
maryland
Could probably take the tailgate off and it’d be wide open access to remove it right?
Ohio5pt7
Ohio
Didnt think of that but you are correct should be
VelocityC6Z
Maryland
I'm not a fan of ricing out a vehicle. But have you seen when they turn on? They may only turn on if you unlock the truck. Extra visibility at nights not bad lol... it's just copper wire, maybe run them into the relay that turns them into the rear window lights so they turn on with your key fob unlock so you have better visibility at night? The glass is sometimes half full lol... and I'm
Half drunkn
Michigan BIGHORN
U.P. Michigan eh
5.7l Hemi (obviously)
Have the EXACT same thing in the EXACT same place on my 2011. It's a LED light strip and I know this for a fact because I installed it only mine plugs into the 4 pin trailer outlet, only wire I had to splice in was for the reverse lights. Hope that helps.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I have the same type of LED tail gate light bar on my 2011. I hard wired mine into the truck. My trailer connector got smashed and trashed. I have another trailer end to install on the truck, just haven’t wired it up yet.
dbdbasd
