Update Uconnect 4C 8.4
Marti12
@SitKneelBend Hello I need some help as well, I upgraded to an 8.4 and I would like to update it. Here are the details. Thanks in advance. IMG_2009.jpeg
Ram1500Truck
Chesterfield, Virginia
Hi all, I have a 2019 Ram 1500 Bighorn 5.7L Hemi. I replaced the starter and once the battery was hooked up the info center shows (Software Update, Update Failed. Please re-insert USB Device.) I tried soft reboot and hard reboot, and nothing works, it stays on this screen. Is there anyone that can help me with this issue? Thanks Bill
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Hi All, I have a 2019 Ram 1500 Bighorn 5.7L Hemi. I replaced the starter and once the battery was hooked up the info center shows Software Update, Update Failed. Please re-insert USB Device. Is there anyone that can help me with this issue? Thanks Bill
Did you do the work yourself or a third party? Do you have factory navigation?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
dfderk
Canada
EcoDiesel
You need Canada firmware. Your firmware is very old but I think it will take v28.3 without breaking it.
Hi. I have an 8.4AN (RA4) head unit currently showing UConnect version 14.47.1. (Hardware Part # 68238626AF) Looking for UCQ (Canada version) software upgrade(s). Thanks.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That firmware is not compatible with an RA4. Different years/manufacturers
dfderk
Canada
EcoDiesel
Thanks for your response. As such, is my only option to upgrade the firmware to 17.43.01 (or higher) is by visiting a dealership? My aim is to acquire an updated map for the NAV system (which stipulates ver 17.43.01 is required). It appeared (from browsing various forums) that IF one could source/download the software it could be upgraded without the need for a visit to the dealership.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I would recommend upgrading the entire radio to a UCS or UCQ. The map updates sold are often a bit old and the new radios allow you to use the always updated map apps of your phone with Android Auto or Apple CarPlay for free.
UCQ also has factory NAV built in but most just rely on their phones once they have them.
