Upgrade evic panel
Beerbill
West Babylon NY
Hey guys. Looking to upgrade the 3.5 evic to the 7. This is a 2017 2500, 6.4 gas. Does anyone know what it means during the part search; "without opt nba" , thanks all
1500ram12
5.9L Cummins
No idea but any 14+ gas cluster (1500/2500/3500) will work.
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
B
Beerbill
West Babylon NY
Thanks for the fast response. I just wanted to make sure that there's not an option out there that I'm not aware of...
1500ram12
5.9L Cummins
I have a cluster out of a 17 1500 in my 18 2500
chris1126
RAMINA
pa
how did you program it? or did you? how does it read your mileage?
1500ram12
5.9L Cummins
Couple different options. Infotainment.com (I believe) does or alfaobd. There is a member on here that still may do it. I'll try and find his name.
Your looking at probably a minimum of a $100 to have either someone else do it and roughly $150 depending on if you have either a android device or a windows laptop.
Mileage is stored in a couple different places as a redundancy. Mileage is stored in the cluster and remains in the cluster as it's own separate memory. Doesn't read from anywhere else.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If the mileage on the replacement EVIC is less than your current EVIC
You need to get a Certified paper with the mileage difference
This protects you when you sell the vehicle to another owner
Under the new rule, the odometer reading must be disclosed at the sale of a 2011 vehicle until 2031. 2012 vehicles will become exempt in 2032 and so on. The immediate impact is that 2011 vehicles will not become odometer exempt on January 1, 2021, as they would have under the older rule.
Dec 2, 2020
THE FEDERAL ODOMETER TAMPERING STATUTES
chris1126
RAMINA
pa
Dec 2, 2020
appriciate the info. i am not worried about selling due to being a truck i am upgrading strictly for show but i do have very low miles so i want to have the exact mileage. so what i gather, alphaobd CAN put the actual mileage on a evic cluster? i currently have a tradesman w the base model cluster.
geneseedennis
