wisey113
Kings finally arrived after about 6 weeks. Hellwig sway bar, core endlinks, moog replacement front end links (the bushings in mine are toast), and replacement front sway bar bushings.
Only thing left are the Icon Delta Joint UCA’s. Those should be here Tuesday.
I had the Kings made to a custom length to eliminate the 4” front spacer from the pro comp lift kit.
I’ll post more as I go along
