Upgrading tires, what will I need?
David38571
Tennessee
I have a 2010 4wd club cab. I'm wanting to put on a set of 35/12.50/20 tires. I've read the thread at the beginning of the thread and based on that I'm going with the Bilstein adj front struts and stirring spacers in the rear. With the stock tires I have about 1/2 in of clearance between the tire sidewall and upper ball joint. With the Bilsteins at max what size wheel spacers will I need to clear the 12.5in tires? This is my daily driver so it rarely sees any off road time. Also, what size rear spacers would give me the clearance but retain some rake?
Thank you in advance.
crazykid1994
Look up the zone diff drop kit. The early 4th gens has an issue with cv angles. The diff drop will help correct that with the leveling kit
