Upper control arms hitting/laying against the coil bucket.
Dusty-92
I've got a 2012 ram 1500 2wd that i recently Installed a 3" leveling kit on.
Now my upper control arms are hitting/laying against the coil bucket.
Would anyone know if the mevotech uca's would give me the clearance I need? Or would I need to spend a ton more money on othe uca's.?
Would anyone recommend anything?
ddetta88
SLC, UT
This is after your tires are back on and the truck is on the ground?
D
Dusty-92
Yes, this is everything bolted back together and tires on the ground. So let me back up a bit. I had about a half an inch gap in between the uca and coil bucket after I had installed the kit and the tire was back on and on the ground. The truck drove really great but my shocks were maxed out and the ride was a bit bouncy. So I added shock extenders and now the uca is touching the coil bucket. So I wasn't sure if I could get rid of the extenders and by a stiffer shock that's not any longer or if I needed to upgrade the uca.
Sorry for all confusion if any at all.
I also appreciate your feedback along with anyone else's.
satxwy
Pentastar 3.6
My guess would be that's just too big of a level kit for a 2wd without running into issues. Did you use coil spring spacers?
