USB port not working
Wrigley17
I have a 2015 crew cab without a jump seat and the charge only USB port on the passenger side. It will work very intermittently at best. Anyone else have this issue? I can't narrow down the fuse that is connected. Any help would be excellent.
W
Wrigley17
That's not cool. Has to be a fix
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Behind the USB interface is a 3" molded in pigtail with the step down module from 12Vdc to 5 Vdc. Behind that module is a simple two wire power/ground connector. If you got good 12Vdc and ground, then that molded in pigtail/USB assembly is bad.
Andy578
Ontario, Canada
2014 Outdoorsman
at first i thought it was by design to preserve the battery but it already kills the power after however long it's set on the radio anyway. it usually seems to work if the truck is just off for 10-15 min but longer then that you have to unplug it and plug it back in before it'll let any power through
W
Wrigley17
Sounds like something the dealer can figure out to me
W
Wrigley17
Does anyone know what fuse controls this USB port on my 2015?
Mbrigh3
IG: Stormtrooper_5.7
MD
Mine just started to do this! I plug my phone into the charger and it will say its charging but then it randomly stops charging and then starts charging again. It does this pattern non stop. This is new and super annoying!
RamCares
n/a
n/a
Hi Mbrigh3,
Sorry to hear about this! If you aren't already we would recommend using a certified charging cord for your brand of phone, the cord that came with your phone usually works best. If this doesn't help and you decide to visit your local dealership for further diagnosis I'd be happy to offer assistance if needed. Just PM our page with your VIN and let me know.
Andrea
Ram Social Care Specialist
