Wow, just checked this thread again. Lots more comments than I expected. I seems like everyone is respecting each other’s opinions and I certainly appreciate the comments pointed my direction. I do feel like I should probably clarify a couple things though. Not correcting, nor counter punching anything, just some detail I’ve left out for “Cliffs Notes” version of the issue.
On doing the work myself, I probably could have done at least the physical swap out of the steering rack. Of course I couldn’t do the alignment or the PCM steering module flash. Also, when I say I like restoring old Jeeps, most of those are in drivable states . I’ll spend a couple months in the evenings draining fluids, replacing gaskets, pull the head off to have it rebuilt somewhere, maybe a new fuel pump, some light fab work for seats, rollbars, etc. I’ve never swapped an engine or anything that in depth. I suppose the difference is that is stuff I WANT to do, not necessarily stuff I HAVE to do to my daily driver. Turning wrenches is a hobby for me. I bought a new truck so I wouldn’t have to do stuff like that.
Second, there was a comment made about why did I continue to drive it once the steering started making its own decisions as to what direction we should go. After the initial steering swerve, which I thought was just my inattentiveness (I mean really, how often does a vehicle decide to turn itself?). After the second more serious swerve, I did pull over and did a walk around to make sure something obvious didn’t happen. Once I didn’t see anything, I nursed it the couple of blocks back to the house. To address the issue of driving it to the dealer, I do have access to a car trailer, however it was my tow rig that was having the problems. I probably could have found someone to pull the truck to the dealer, but instead chose to drive it late evening, with minimal traffic to the dealer while my wife followed behind. Was that the safest way to do it? Probably not. It was a known risk however and since there really was nothing actually broken and hanging off the truck, I took it as an acceptable risk.
Finally, for the comment regarding checking the connection to the power assist motor.. yeah, maybe I should have done that. To be honest, it never occurred to me to unplug it and plug it back in. Does anyone think that might have been on the FCA steering troubleshooting guide that the dealer would have checked? Testing voltage and resistance through the plugs and to the motor before they decided to replace the entire unit?
Again, thanks everyone for the replies. Been driving the truck since Tuesday and it’s been going the directions I point it.
