Vararam intake
Pull Ya
Cedar Creek, Tx
Thank you
Jay
ramwad
Labelle
I am looking at getting one and don't want to jack this thread but with the paint ready option did ya'll spray paint them? I found the match for my truck and wanted to paint the cover piece the same and wanted to know if that will be good enough. I got a can of primer/color/clear and didn't know if I needed to light sand it before the primer or what steps did you take. Thanks in advance and they do look nice and I really like the look of these intakes.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Prep prep prep
I sanded, used some putty on imperfections, sanded agaiin.
Primed then wet sanded
Primed again
Taped off and sprayed black.
Dried for a couple days
Taped off black and sprayed white.
Dried a couple days
Multiple coats of clear
Take your time, use same brand of primer and paint
2012RAM1500RT
2012RAM1500RT
NC
Y
Yes Sir, Not saying what I did is right but I ordered the black wrinkle finished one, (you may decide to get the smooth finished one) and decided when I got it I wanted it the same color as my truck so I cleaned it well with purple power cleaner and wiped it down with paint thinner (be careful and test a spot inside first because it acted like it softened the plastic if you saturate the cloth, so test first) otherwise after I cleaned it I sprayed it with an aerosol plastic paint, 3 coats, no primer or clear coat. I don't know about longevity yet since it's only been 2 weeks but I'm very happy with it so far. Hope that helps you some.
ramwad
Labelle
Good points. I am going with the smooth one and all the paint came from the same place.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
2012RAM1500RT
2012RAM1500RT
NC
Thanks, I had to get them off of ebay. They are like the wing nuts that came with the big round chrome air cleaner we use to get back in the day.
Arturo Rojas
